Hi folks!!
Brush Stocker 1.12 is available.
Version 1.12
Bug fix
AlterPick didn’t work when pushing ‘Number’ key to change brush
AlterPick didn’t work when brush set is loaded
New feature
New shortcut keys to change color are available
‘Y’ key : Select brighter color
‘N’ key : Select darker color
‘G’ key : Select paler color
‘J’ key : Select deeper color
(See HSB palette)
Restoring below parameter is available
*Draw sub parameter
MRGB mode
Z mode
*Stroke sub parameter
Directional brush stroke
Spacing
Placement variance
Scale variance
Color intencity variance
Flow variance
*Alpha sub parameter
Alpha blur
Alpha noise
Maxmize range
Radial fade
If you haven’t downloaded previous version, please download Icon set and extract it to same folder that the script is saved.
Enjoy ZBrushing!!
kaz-g
