ZRemesher polypaint density not working
hi,
I’m using ZRemesher to retopologise a simple human figure. I’ve done so many times and used the polypaint density function to get more polygons around the face, less on the back etc.
Suddenly it’s stopped working.
Could anyone suggest a reason why this might be so?
thanks
j
Same Problem here!
Have you found a solution?
Best,
Lapislazuli
hi.
no I’ve not found anything.
It doesn’t seen to be a common problem either, as there no other replies on the subject here I see.
Anyone found a solution? I can’t get this to work on Mac OSX R8.
I’ve found that it just doesn’t work on the 64bit version - I resorted to using the 32 version of 4r7
