When I’m adding new topology to my model, the lines that I create from projecting new topology off the zsphere aren’t showing up and it’s making things difficult to add seeing how that I can see where they are. Where can I adjust it so that the lines and points that I’m drawing in for the new topology are visible?
Have you saved your work in a previous session and are now picking it up again? If so, turn off Tool>Topology>Edit Topology, then turn it back on again.
If you continue to have trouble, we’ll need more info and screen shots.
Turning off the Edit Topology got rid of some of my topology for whatever strange reason but it worked turning back on my edges. Thanks a lot, appreciate it.
