Hi there,
I’m trying to project a high res detail model onto a plane to extract a really good normal map from it. I’m using zbrush 3.5 R3. Ive noticed that the tranpose tools don’t work on zproject anymore? The geometry has to be directly on top of the plane in order to work? Is there a way to fix that so i can “clone” to parts of the plane.
Also I noticed that zproject isn’t that strong? if the detail mesh is a little high from the plane then it won’t project anymore? Is there a way to fix that? I tried subdividing the plane an awful lot in order to try to project it but then I would be using up alot of memory. Any information would be helpful thanks! Still a little new to zbrush 3.5
