ZProject & Image Plane4
I’ve created a head tool that I want to texture using high quality reference textures.
What is the best way to get my texture and tool both at the right scale so I can then ZProject the texture down. My reference textures are big, 3k to 4k in size at 300 dpi. What's the best way to do this please ? Edit: I've found this from Marcus in another thread:
  1. Turn off Document>Pro.
    2. Set Document>Width to xxxx and Document>Height to xxxx.
    3. Press Document>Resize.
    4. Use the Zoom>Zoom Doc button to scale the canvas so you can see it all.
I just can't find the Zoom Doc button, did that refer to a different version. I'm using ZB4
I would think the best way would be to use Spotlight. You could also use Zapplink.
Damn !! That Spotlight looks like a really sexy tool.
I will definitely give it a go. Thanks
No problem! If you havn’t already, check out the Spotlight tuts in ZClassroom.
