Zproject brush
I was following an earlier tutorial about using zproject brush to paint demo head onto vase to the tee.It wont paint the demo head onto the vase at all.I even tried various angles like even having the head a little out front of the vase with no results.In the video your supposed to activate the vase in subtools then click on the move button and draw your transpose or zproject line starting from the vase to the cheek area of the head.Then click on draw, and paint on the vase.I even went thru the steps of just using 2 primatives without success.I get as far as apending the 2nd object into subtools and repositioning everything like the video points out with no results.Now this is a older video and am wondering if Z4 has changed the procedure. Is their a way to quick check “zproject brush”?
Thanx in advance
That video is out of date. The zproject brush is no longer tied into the transpose tools. To use it the model needs to be directly on top of the area you want projected. So instead of moving the transpose lines you move the model around the canvas to pick up areas of texture that you want.
