Zplugins
Hi, I guess all plugins for zbrush 3.1 will not work in zbrush 3.5!
Ok I see they are not, next think, when uploading alpha textures I see only JPG thumbnails but no PSD, this is not too good
I have the same problem with plugins! Hope you guys can fix it soon!!
Actualy, I have a huge problem becouse I can’t use TposeMaster to pose my character, and I’m running out of time!! HELP!
We are working to release 3.5 versions of the plugins as quickly as we can. Until then, if you need a plugin from 3.1 my recommendation is just to run 3.1. We’ll continue supporting it until the plugins have come out for 3.5, and having it on your system won’t interfere with 3.5.
There are ways to get a model from 3.5 into 3.1. You basically export both the high and low subdivision levels as OBJ files. Import the low level into 3.1, divide it to have the right number of subdivision levels, then import the high level. Done!
Thanks for info aurick!
