Hi xueqing0622,
Thanks for trying the plugin. I agree it would be good to see how the Z Intensity changes but unfortunately it can’t be done in zscripting.
Hi xueqing0622,
Thanks for your reply, Marcus
Thanks for the great plugin, Marcus !!! I love it
Thanks Marcus for a great script. I’ve started using Zbrush again and recently downloaded your MaxCanvas script, It works really well with this plugin. But have you or anybody used Silo2 beta? their displacement painting works really well using just the - MMB - adjust radius and strength of the current brush. Drag left/right for radius, up/down for strength. This shortens key strokes even more (you don’t use any) Would you be able to code a similar script like this?
A Merry Christmas to all.
Hi DigitalDreamer,
I’m glad you like the plugin.
Yes, I’ve used the Silo beta and I know the functionality you’re talking of. It would certainly be possible to script something similar, though I shall probably leave doing it until the release of the update.
Happy Christmas to you!
Cheers,
OK thanks Marcus, looking forward to that.
Merry Christmas to you!
Marcus. thanks heaps for this little plug. i’ve been using it a good while now but one thing has always bugged me. and it might just be my setup. not sure. but i get this inconsistency with the resizing of my brush. seems like most of the time it evaluates the size from the left edge of the canvas ( the effect being that if my starting location is beyond 256 pixels from that edge. say. the cursor will jump straight to 256 in size. my default max. and i’ll have to resize from there ). and sometimes it’s even a little random. neither of these bahaviours are preferable. i’d like for the increase / decrease to begin from the current brush size and be calculated from there. would it be possible for you to make this edit ? or. alternatively. make public the code and i’d tinker with it myself ?
tacit math,
I’m glad you find the plugin useful.
The problems you are having may be due in part to your set up (zscripts appear to work slightly differently on different set ups) but also the nature of the script can also throw up these effects in specific circumstances. In part this stems from the fact that if you hold down the script hotkey (in this case ‘S’) the script continually reloads - a ‘feature’ of all zscripted plugins. I’ve had to script around this.
You’ll appreciate that for the script to work I have to grab a starting point on the canvas and then measure mouse movement. This starting point is only deleted from memory when the mouse or pen button is clicked. (It can’t be when the script exits for the reason given above.) So if you click the hotkey once, move the mouse to the right, then click the hotkey again there will be jump in Draw Size such as you describe. In my testing it’s quite easy to do this inadvertently and perhaps that is what you are doing. (Note you should be able to adjust the size anywhere on the canvas area or background. If you can’t check you have the latest version from post# 31.)
I’d certainly like to get rid of this behaviour and I hope to revisit the code soon.
Cheers,
thanks for the reply Marcus. well. if the nature of a zScript is as you describe. refreshing itself in that manner. we might be a little screwed. i can indeed resize my cursor from anywhere on the canvas. but yeah. 'cept it ’ jumps ’ directly to whatever size seemingly regardless of the current size of my brush. all in all though the script is an aid to workflow ( i appreciate the fact that it’s activated without the unnecessary need to ’ click & drag ’ ). and while i feel it could do with some tweaks i thank you again for writing it up just the same
