This is a rework of a zplugin I posted earlier. It makes it easy to adjust Draw Size, Focal Shift and Z Itensity while you’re working simply by moving the mouse left or right while pressing the hotkeys:
Hotkey [S] sets the Draw Size
Hotkey [1] sets the Z Itensity (and the RGB Itensity when the sliders are locked in 2.5D mode)
Hotkey [2] sets the Focal Shift
Clicking the mouse/pen after adjusting recalls the previous zscript so your workflow is not interrupted.
Unzip the zip to your ZStartup\ZPlugs folder and the hotkeys will be available next time you start ZBrush. NOTE: if you installed the previous DrawSizeSweep.zsc this should be deleted or the new hotkeys will not function properly.
The zip contains three files:
AdjDrawSize.zsc
AdjFocalShift.zsc
AdjZInt.zsc
Simply delete the relevant file if you don’t want that hotkey.
I hope you find these hotkeys useful.
small_orange_diamond
