ZModeler questions
Hello.
I have couple questions about zmodeler.
  1. How with zmodeler simple extrude polygons by polygons. Zmodeler extrude by group.
  2. How extrude border edge?
Thanks.
By default extrudes by polygon
  1. How extrude border edge?
You cant
Hello and thanks for your answers.
Is possible to extrude by polygons normals.
And couple questions more:
1)How to brake the vertex, is it possible?
  1. Zremesh doesn’t understand radial symmetry for remeshing?
By default you will get the first image result, clicking in one poly, qmesh or extruding and repeating in the other poly. By default it will extrude only single polys. You need to select two polys with alt (or other systems) in other to get the second result.
By default qmesh and extrude in Zmodeler will extrude by normals.
Break=brake?
You can not break individual vertex but if you press ctrl when extruding you will get a detached copy. Also in tools>geometry you can break all vertex in the polygroup boundaries.
About radial symmetry I think it works as long you model fits exactly with that radial symmetry, otherwise will be a mesh.
