How in ZModeler to cut the polygon diagonally?
How in ZModeler to cut many polygons over them.
How can I delete a edge that ZModeler does not want to delete?
Point action - Bridge, Target - two points. Click on first point, then on the second.
a) with SliceCurve brush. It will cut all polygons that you tuch (then delete unnecessary points with Point action - Stitch).
b) select neened polygons, then apply Polygon actions - insert polyloops.
c) Edge actions - Insert, Target - single edgeloop. It’s for creating an edgeloop.
- Edges can be deleted only when final polygon has 4 sides, in that case when there will be N-gon (more than 4 sides) an edge can’t be deleted.
