zmodeler insert edge loop symmetry
Hi, I’m trying to sketch out the lines for a building foundation, so symmetry would help me make sure lines are even, e.g. walls are same thickness. Anyways, the answer could help me with lots of other things. I turn on symmetry but when I insert an edge loop via the zmodeler brush only one appears. There is another point that appears symmetrically, but not the edge loop. Is there a way to enable this? Thank you.
well I’ve just inserted multiple edge loops and transposed them, seems to work for now.
