Zmodeler glitch: Disappearing geometry
All of a sudden, I have been having a problem with disappearing geometry when I use Zmodeler. I qmesh a poly and the whole model just poofs except for the polys resultant of the operation. Same happens for extrude. I’ve also had trouble with seemingly random polys disappearing. I go to bridge two edges and poof! Gone. They also sometimes disappear when I mirror and weld.
I hit double sided and the invisible polys are still not there which tells me it’s not so simple as flipped normals. I’ve tried exporting and reimporting. I’ve tried exporting, reimporting, and saving as a ZTL but zbrush does not recognize the tool type. I’ve tried exporting it into blender and exporting it but I keep getting the same problems. I’ve also tried mesh integrity.
As far as I know, this is only a problem for this particular model. I tested zmodeler on a cube and everything was in working order.
I also somehow ended up with two models occupying the exact same space which is causing all kinds of quantum buggery.
Thoughts?
If you have hidden polygons you could have glitchy effects. If this is not the problem try make polymesh 3d or geometry>meshintegrity.
