Zmapper problem
Hi
i have a problem with zmapper plugin .i start with the base mesh on max and make uv then transfer to zbrush and add some details after that lower the sdiv to 4 then i try to make the map but this’s what appear below, when click ok it appear more and more as you see . how to solve it??
http://img155.imageshack.us/img155/4304/zb1.jpg
http://img155.imageshack.us/img155/2457/zb2.jpg
ZMapper requires OpenGL. Either your graphics card or its drivers doesn’t support it. Try installing the most current drivers from the card manufacturer’s website. If that doesn’t work, you’ll need a different card that does support OpenGL.
