Hello guys
i just want to share something that i working in my free time in a past 2 years .
I want to give a big thanks to ??rcus Civis , for the big help on the scripts. Thanks man you are great !!!
Here is a description of what the plugins does:
HUMAN ZBUILDER v2 THE EASY WAY TO MAKE HUMANS
for Zbrush 4R7 P3 64bit WIN OR OSX
Tool for making detailed high polygon human models in Zbrush
Human ZBuilder is a plugin for Zbrush. With this plugin you can make any types of human bodies and custom body types as a creatures or humanoids…
FEATURES:
EDIT POSE: will allow you to make basic pose of your model.You can save or load your pose.
EDIT MODEL: will allow you to edit your own model and integrate it into zbuilder plugin as a custom preset. And continue using all zbuilder features.
EDIT RENDER: will allow you to make great presentation of your model. The scene is set with the best settings as materials, lightings and fibbers presets for easy use.
GET MODEL: will allow you to get the finished model and use it for any purpose that you want.
10 colorized layers for great blending between them
the models is good for close up renders ,animations and etc.
50 MORPH controlled for ( body types, face types , expressions and etc.)
presets for Materials, Dramatic Lighting, Rendering ,SSS,Ao,Shadows, backgrounds and etc. For BPR render.
You can use the tool for commercial or noncommercial purposes.
you can’t resell it
video :
https://youtu.be/GWO4nk6Fo-w
Want to buy : https://gumroad.com/l/bkElP#
Hope you will like it
