Zbrushcore. Missing stroke when using Wacom pen.
i am using Zbrushcore and a Wacom Intuos Pro tablet.
When I use the mouse, my strokes work fine, no matter the brush I use. However, when working with the Wacom pen, there is always a missing part in all strokes. The missing part occurs at the begining of the stroke. It is very noticeable when using the Standard brush, but happens with all brushes. The missing parts corresponds with the time the circle cursor is visible, which occurs for almost a full second when using the pen.
For instance, if I start drawing at point X=10, the circle cursor appears when i put down the pen, then I start dragging the pen horizontally , say to X=100. While the cursor is ON nothing is drawn. So, I end with a stroke that start at X=30 to X=100. The segment between X=10 to X=29 is missing.
I dont have “lazy mouse” enabled. On “Windows Pen configuration” I have tried “Enable Press and hold” ON and OFF with same result. I have tried with several stroke types.
The problem does not happen when using other tools, like Painter, for example.
I have tried with both USB and BT interfaces; same problem.
I am missing something on Wacom or perhaps Zbrush configuration?
Windows 10 64bit. i5. 32GB.
Wacom Intuos Pro.
Zbrushcore .
