Zbrush3.5R3 - Size problem.
Hi.
When i export from Zbrush my tool to .stl file, the programm create a file with a size of 1Kb. In MagicsRp, i import recently created file. and it types me that
the siza of the model is too small.
In Zbrush i try too Unify my model; use Deformation - Scale and increase size of the model in 20 -30 times; Update size Ratios, but was the same effect… :confused:
In Zbrush3.1, I created from my tool .stl again and imported it in MagicsRp. Everything was ok.
What’s wrong with R3 version ? How to fix it ?
You should make sure you have the latest version of the 3DPrint Exporter plugin from the Download Center. Before updating, please, remove the existing 3DPrint Exporter plugin (the .zsc and the datafolder) from the ZStartup\ZPlugs folder.
