ZBrush2 Manual
When will the new manual for ZBrush2 be available? I tried to download it from the website but the link is dead on every page I found it.
Thanks
It’s available here
…and the manual (reference)?
cameyo
Hi cameyo,
ZBrush 2’s reference information is built directly into it in the form of the Help browser system and the Ctrl key (which brings up detailed information about any element that you point at with your mouse). This would render a PDF reference manual redundant.
That’s not to say that we won’t eventually produce one, but we have higher priorities at the moment.
Thank you Aurick.
I can imagine your priority (ZMac and ZDemo) :slight_smile:
I wish point out the problems with the actual help system:
  1. if i don’t known where is an item (or if it do not exists anymore) i can’t be able to obtain info about that item
  2. if i want read it in bathroom … i can’t
  3. if i want write some more info or highlight on some subject…i can’t
    I hope you’ll consider this problems and will write a reference after your actual priority.
Anyway, thank you and Pixologic for your works.
cameyo
