Zbrush window always on top.
So I’m running Z-brush 4r6 on a windows 7 machine.
It has worked fine for me for months, but today, it began to always display the z-brush window on top of the interface, even if it is not the active program.
So I could try to work in a web browser and select it, but the web browser or any other window will not display in front of z-brush.
I’m pretty much forced to minimize the z-brush window if I need to use anything on the same monitor to it.
Is this a bug? Did I push a button to activate this?
Just looking to fix this, as I find it weird that I haven’t run into this problem for years before today.
You do have ZB4R6 P2? You could try to blame a Windows update. Hadn’t noticed a problem here.
