ZBrush will not save, load, export, import anything
I’m using the zbrush4 trial and have not had this problem before. When I try to save my project, the cursor will change as if the computer is thinking for a SPLIT SECOND and then change back to normal and nothing happens. It’s the same thing when I try to load, export, or import ANYTHING in zbrush, even brushes and textures. I really don’t want to lose the work that I’ve done today, is there any way I can salvage what I’ve done?
Also sorry if this has been answered before, I tried searching in this forum but I got a fatal error message in the browser every time o_O If this has been answered can someone please stick a link in here, thank you.
It sounds like your installation has become corrupted somehow.
What plugins or other ZStartup items have been installed? Are there more than 25 of any given item? Are any plugins not from Pixologic?
Have you made any changes to the ZData folder’s contents?
One option is to uninstall the Trial, delete its folder, then reinstall again. That should resolve whatever is going on.
I ended up restarting ZBrush, and everything worked again >_> so I lost my work but at least I was faster at redoing it. Really weird bug. I only added UV Master from the ZBrush website. Thanks anywho =)
