Im running a 55gig(60 gigs on the label) SSD hard drive for my OS drive, but even with regular pruning and cleaning, I cant keep more then 5 or 6 gigs free-space. As Zbrush writes its Ztemp files to C:, I’m am running up against a few models on which I constantly run out of virtual memory when attempting to work on geometry layers causing Zbrush to crash. Is there any way to set Zbrush to write these files to a drive other then my C: drive. If not I’ll bite the bullet and spring for a new 120 gig SSD to run my OS on. thanks for your help
I’m afraid it’s not currently possible to change the drive that ZBrush uses for its virtual memory - it is always the same drive that ZBrush is installed on.
