Im using zbrush 3.12. There are 2 problem that i cant solve.
First is when i use projection master. The texture is disable. I cant click it. Is this normal. I know previous version can.
Second was. The edit curve problem. When i use edit curve - noise. it wont work. The value snap and the graph is gray. It should be a noisy graph but it turn out to be a gray graph. Any idea ??
