Need help, i’m using zbrush for a month, everything was worked fine but today while sculpting for no reason the ctrl+z (undo function) stoped working, or, it may work when i move with the camera arround the object but immediately will stop to work again. I’ve tried to set the undo function to a different key and no help either. I’ve tried to google, but found nothing… tried also pc restart, reinstalling zbrush, no help… it’s incredibly annoying… has anyone encountered this? thanks
in short: the undo function through hotkey works, but incorrectly, it behaves like it’s bugged… clicking on undo from menu works without any problems, but if i do use it through hotkeys, be it ctrl+z or any different that was customized for it… it will work only if it wants or it may not work at all…
