I know that you can get modo to work the way Zbrush does when you turn on pointselect, but I can’t for the life of me figure out how. I don’t want to have to encompass an entire polygon, edge, etc to have to select it.
Anyone happen to know?
Do you mean lasso mode? You can select by vertices (1 key) and convert to polygons (Alt-3) . . . normally Modo requires you circle the whole thing (point, edge, or poly) to select with the lasso.
The Modo doc for the Lasso says " Geometry must be fully enclosed in the lasso to be selected."
-K
BAH!!!
Thanks Kerwin. I didn’t mean lasso, you knew what I meant…hmm…I’d rather not have to encompass the whole polygon, edge, etc. But I guess I’ll get used to it.
