ZBrush Trial Wont Start
Hey,
Just got a ZBrush trial, and it worked fine at first, made something, saved it etc. fine.
Just tried to re-launch it and it goes to the grey loading screen with the ZBrush 3.1 logo, makes a noise that I think means error or something (y’know the type) and never launches, just stays on that screen…
Any Helpers?
Ta, Mike.
Have you installed any plugins or other startup files? Made any changes to your system?
Nope not at all =/
It worked fine, then like an hour later I tried to restart it but I got that problem :frowning:
What are your system specs, and does it have RAID drives?
(By the way, you really should contact [email protected]. That’s what the team’s there for. :))
e6750 @ 3.5ghz
2x 8800 ultra sli
780i
2gb ram
2x 250gb raid 0
it worked the first time so idk why specs matter… =/
I asked about system specs because it helps to have as much information as possible when troubleshooting. In this case, one of your system specs is exactly why you’re having the problem. This is a documented system hardware issue:
http://www.pixologic.com/docs/index.php/Licensing#RAID_Drives
We are hoping that this problem will be able to be resolved with ZBrush 3.5. It’s not going to be possible to resolve it for 3.1.
=o
Dude thanks like this much <------------>
:lol:
It’s a relief to actually know what’s wrong =P
Guess I’ll see about sorting that out then :slight_smile:
Thanks again
mike
