hi , i need to export my model from zbrush to solidworks … if i can export it as a .igs format it would be great … how can i do it … thanx a lot
I don’t think that ZBrush can export that format. I’m not sure, but I thought that Solidworks could import STL files. If it does, you can use 3D Print Exporter plugin to export STL files out of ZBrush. You can export STL Ascii and STL Binary.
wow that’s what i wanted …thanx a lot
