Hello :),
I’m having some odd displacement results, I almost have it working perfectly but I have some small issues I can’t seem to resolve.
First of all, this is how the shirt looks like in ZBrush:
[http://img8.imageshack.us/img8/4493/shirtzbrush.jpg](http://img8.imageshack.us/img8/4493/shirtzbrush.jpg)
And this is how the collar of the shirt looks like in ZBrush:
[http://img9.imageshack.us/img9/7770/collarzbrush.jpg](http://img9.imageshack.us/img9/7770/collarzbrush.jpg)
I've exported first subdivision level of the mesh from ZBrush to maya and made displacement maps.
This is how the shirt looks like in Maya with <b>regular displacement settings (Feature displacement, no Approximation nodes)</b>, parameters are in the pic as well, overall it looks allright, though the displacements are kind of weak compared to the ZBrush version:
[http://img7.imageshack.us/img7/2619/shirtmaya.jpg](http://img7.imageshack.us/img7/2619/shirtmaya.jpg)
And this is how the collar looks like with the displacements in maya, it looks inflated a bit and weird, also nothing like the collar in ZBrush..
If I take the Alpha Gain down of course it looks better but then the displacements are not visible at all and if I take it up it looks even worse:
[http://img14.imageshack.us/img14/1671/collarmaya.jpg](http://img14.imageshack.us/img14/1671/collarmaya.jpg)
This is how the shirt looks like inside maya with the displacement and with a normal map, a hell lot better, however, the collar now looks terrible:
http://img8.imageshack.us/img8/7119/shirtmayanormal.jpg
And the collar with the normal map:
http://img24.imageshack.us/img24/6627/collarmayanormal.jpg
And this is how the mesh looks like inside Maya with a Subdivisions Approximanion node, for some reason some parts are messed up, like the part marked in the image, it also happens in the backside of the arm:
[http://img4.imageshack.us/img4/1566/shirtmayaapprox.jpg](http://img4.imageshack.us/img4/1566/shirtmayaapprox.jpg)
So basically my questions are:
1. Why does the collar look so bad and how do I fix it?
2. Why does the Approximation node gives messed up results although it should give better ones?
Thanks a lot
