Does anyone know why when i send some thing for maya 2014 to zbrush4r6 it works just find,but then when ever i try to send anything from zbrush to maya 2014 it opens up in a instance of maya?? I didnt use to do this i maya 2010 to 2013. How do i fix it?
Try to delete your GoZ shelf in Maya and start again.
If it doesn’t change, check if Maya OR ZBrush isn’t executed as an administrator (both shouldn’t).
Eventually, reinstall GoZ by executing the GoZ installer located in the ZBrush troubleshoot help folder located in the root of ZBrush, then relaunch GoZ in ZBrush to respecify the target app.
