Hi There
Hope to make this a kinda trouble shoot FAQ thread maybe? But I got the bridge bundle and ran into a few snags. I immediately opened my previous models to see how ZB and KS will handle them. I have some pretty big scenes. The irony is that the smaller scenes does not seem to want to go to keyshot. But the more complex (42 subtools - 36 mil polys) did its thing after a waiting a bit. So wondering is there a trouble shoot guide or something in my scene causing zbrush to freeze?
Cause if you cancel the export to ks command zbrush bombs and you have to exit all programs. Then the other project pretty big but not the biggest I waited very long to go to keyshot and then saving from keyshot my file size was 12 GB !!! So just wondering if a patch or maybe a ZB to KS for dummies might be available some where?
But when it works wow it is simply genius! Below had to make slight adjustments lighting and material to get it back to the look I wanted but very little. This mech is a very heavy scene and worked pretty well, tad slow. But other scenes less complex did not so wondering something in my scene or just bugs that need to be worked out? Comment and feedback regarding plugin would be great!.
- I am probably the problem doing something weird… I have this funny feeling that new projects will go smoothly and that there is something somewhere causing this, due to versions but would be great if I knew what to look for. I tried going through each subtool but zbrush crashes if you cancel import to ks so it’s a bit of a frustrating test. But when I have time will do it again.
