Zbrush to Keyshot bridge...getting a error message????
Ok I’m getting a error message when using the zbrush keyshot bridge and it says “Out of memory (requesting 36541 mb)!!! This may cause instabilities.”
My model is a totalpoints: 27, 938 Mil. Is this to big??? It worked when I took one subtool at a time, meaning I deleted all the other subtools and brought in one at a time. The problem I’m having with that is that when I bring them over to keyshot they never go to the right place meaning if I bring over the body then bring over he teeth, the teeth never import to the mouth like its suppose to.
What can I do. please, what can I do
Thanks
27 million polys would kill Keyshot for me too (especial if it is fibermesh heavy), even after a manual import of subtools.
To manually import and have the subtools (as obj’s) in the right places, you need to import the first one in Keyshot. Then in the import settings dialog for the second and subsequent obj’s you should in “Position” tick “keep original” and for “Scale” tick “same as last”.
