Zbrush to 3ds max Goz button
Help please, when i export my 3ds max model to zbrush using goz button, everything works.
When i edit the model in zbrush and want to bring it back to 3ds max, i press the goz button in zbrush
but then it opens another window of 3ds max and not the same window that has my original model…
plus the file that it opens in max is just an empty one with no zbrush model :frowning:
what’s wrong?
Are you on Windows?
If so, do you have either ZBrush or Max set to “Run as Administrator”? If one is set to run that way, the other must as well or GoZ will not work correctly.
If that does not resolve the issue I would recommend reinstalling GoZ. You can do this by running the installer found in your ZBrush installation’s Troubleshoot Help folder.
