Zbrush Subtool Master Problem
hello i have a subtool master problem
when i make any thing in this plugin
like miror or duplicate
it pop up a message tell me "Zscript note interface item could not be found
popup : Mir#4_goggles
in
{Ipress,{strmerge,“popup:”,[VAR,CURRENT SUBTOOL]]]
I Hope any one can help
thank u
Which version of ZBrush are you using? Which version of SubTool Master?
iam using zbrush 3.5 r3
and the subtool 1.2g
I’m also having a problem with the subtool master plug-in in 3.5r3 for PC. When I import multiple objects at the same time, it just throws everything on top of one another. How can I get it to drop everything in place the same way it left Maya? I’m only trying this approach because I’m can’t seem to get anything to import the way it’s supposed to with correct a working X symmetry. I’ve tried smart resym, resym, s. pivot, c.pivot, and even tried adjusting the pivot with the preview pallet. Every attempt is a dead end. What can you recommend?
