Zbrush starts offscreen.
I have duel monitors, one above and below. Every time i start zbrush I’m forced to change my display properties so it thinks my second monitor is on the right so i can access zbrush’s restore tool. Most programs wouldn’t be a problem because you can double click the top of the window and it restores.
anyone know how to fix this?
The first thing to try is to close ZBrush and then delete the contents of the ZStartup\ConfigFiles folder.
When you restart ZBrush after that, it should now be filling your primary monitor.
Alternatively, you can use the title bar to drag it to the upper left corner of the monitor where you want it. Then drag the sides of the window to fill the monitor. (Don’t use the Maximize or Restore button.) Once the window is sized and positioned how you want it, press Ctrl+Shift+I to store the configuration which will now include the window position.
Thank you for such a fast response. Ctrl+Shift+I worked perfectly. Thanks again.
~J
