ZBrush single/dual Monitor issue
I have installed ZBrush 4 on my laptop; At home I use a second display, on which I display ZBrush.
when I work without the second display, zbrush still thinks there is a second display, so it does not show up on my laptop´s display.
this is not an issue as long as I move the ZBrush interface while having the second Displayrunning.
but when i have i.e. an appointment with a custumer and want to show something in zbrush, i sometimes have the problem that i can´t make zbrush show up on my laptop monitor, as it still thinks that there is a second monitor active (even if in the nvidia settings there is only one monitor - the laptop display - available). This is the case if I have not moved the zbrush interface to the laptop display before removing the second display.
as this issue always shows up when i really don´t need it I wonder if there is a sollution to move the Zbrush interface on the laptop display without plugging in a second display?
cheers m
