hi,
anyone else feels the same about the wire of the mesh the retopo brush creates, its just too thin? An option for making it thicker would be welcome!
As an example I made it thicker in photoshop.
hi,
Another problem with this brush.
I’m doing retopology in ZBrush, and I’m running into an issue where polygons I’ve already laid out in the background interfere with the polygons I’m creating in the foreground.
ZBrush doesn’t properly cull or ignore overlapping polygons during retopo, so the Retopo/Topology Brush still detects faces that are behind the surface I’m working on. Because of this, it can snap to or connect with existing polygons instead of the visible surface, which often results in overlapping or incorrect geometry.
As shown in the image, the polygons inside the circled area are being influenced by previously created faces behind them, even though they’re not meant to interact.
