Since r2 and upon seeing the EAT 3D hard surface video…I have been used to the Custom Menu Workflow…If you use this workflow, be prepared to cry a little…
Since then I’ve had an issue which once was fixed with UI_Starter plugin…in r4 it appears that it does not work…
When you make a custom menu or “pallet”- it shoots back in alphabetical order at the top, customize and put all the tools you use and store configs…restart Zbrush and BAM…every time you try to open your custom menu or the lets say “preferences” it opens the “render” pallet…Oddly enough though in r4, everything BEFORE your custom menu works fine when you try to open the pallet, but everything AFTER the custom menu is 1 pallet off…
Not only that but I tried putting some TRANSFORM options “Symmetry, xyz and radial” into my CUSTOM menu, and once I stored and restarted and my strokes section in my CUSTOM menu became " Active Symmetry " followed by “make polymesh 3D, goZ, All, Clone Allsubtools” No idea what that’s about…
1St I imported my r3 settings and tried - didn’t work…then I reinstalled Zbrush and deleted all folders in my program files and in the new Public Documents Folder…made it in r4 from scratch same issue…so It has nothing to do with the old settings being incompatible with r4…If anyone can help I’d appreciate it or knows of a fix like an updated version of UI_starter
Such as the one at the bottom of this link: http://www.zbrushcentral.com/showthread.php?160733-ZBrush-4R2-Troubleshooting-FAQ...I’d appreciate it
