ZBrush PolyGroupIt 2018 problem...plz help
how can I run Zbrush without this problem?
In the main ZBrush folder there is a folder called Troubleshoot Help. You need to run the vcredist in that folder to install extra Microsoft files. The vcredist_2017_x64.exe will probably be enough.
I have installed all programs located in the file , but the problem still exists
See if this helps…
https://support.pixologic.com/Knowledgebase/Article/View/261/71/polygroupit-wont-run-on-an-nvidia-gpu-that-is-opengl33-or-above
You could also try updating your video card drivers or re-installing them.
You should probably submit a ticket to Pixologic Support.
