Hi everyone!
I’ve just started to work with ZBrush and I have a question about performance.
The problem is when I try to make some objects (sphere, for example) with number of polygons more than 8 millions ZBrush displays error (that I should change maximum number of polygons in Preferences). But after I change MaxPolyPerMesh and HD Preview Max Poly to maximum and then again try to make more polygons ZBrush freeze for a while and then crashes.
I already went to Preferences and set up Mem->Compact Mem to maximum value (4096). I also reduce number of undo history to 100. It helps, but not as much as I expected.
Also when I add this “more than 8 millions” polygons, in Task Manager I see that CPU is busy for 99%, but only 2 Gb RAM used by ZBrush and I have ~50% RAM free.
My computer configuration:
Core i5 3570
8 Gb RAM
GTX 660 (but I’m not sure ZBrush use it).
How can I improve ZBrush performance on my PC?
