Quick question. How do you reset the Brush Pallet back to the default brushes in ZB4R2> Right now I have about every brush loaded in the pallet and cannot remove them to get back to ZBrushes defaults!:mad:
Thanks
Thanks
I am relative new to contributing here, so I’ll tell you…the absolute easiest way is to quit zbrush and restart.
I’m not sure what you mean here.
If you mean restore the default brush settings, there is a button at the bottom of the Brush picker window called “Reset all Brushes”.
If you mean clear the list of recently used brushes, click the “R” button in the Brush menu (the one on the top shelf), underneath the "save as " and “selection” buttons, to the right of the item info slider.
If you mean you have customized your startup brush menu by adding brushes to that file, you need to remove the brushes you have added there and use the Lightbox directories instead.
