- Why when you paint through Projection Master (AKA on the texture), with a part of the model out of the canvas (because we need paint details) the painting appears in places where the model it wasn’t visible on the canvas?
This is a really disturbing bug, we NEED paint detail. Pixologic should fix this or present each us a 30 inches monitor.
Did you imagine you are sculpting some detail, and when you zoom out, you find this detail tiled over all your model? A nightmare?, well, the don’t try to paint!!.
Yes, it is. Using the tool Directional Brush, but it take a bug if you need use an alpha for it. The alpha will be cutted cleanly for one of its sides.
Why with Nudge, Move, and Pinch Tools, we can’t paint & sculpt simultaneously?
Can we get in a customize interface the curves graphics (brush menu> Smoothing Curve, or Edit Curve)?
Why “Disable Uv” destroys Uvs?. Not should it “disables” it?
Why if you mask an area because you don’t want paint on it, and you paint near it using Projection Master, the Mask is painted too?
Why we can’t see our model in “smoothed mode”, like the soft edges in maya?, or the soft view of Mudbox?. I we want simply paint it (without sculpt), it will help us very much.
Will be so difficult a tool that behaves as a combination of Drag Rect and DragDot tools? Draw a stroke with Drag Rect and press Spacebar, swich while to DragDot, release Spacebar and back to the Drag Rect tool.
This way will avoid us draw twenty times the same damn stroke from the “perfect center” of the area we need paint.
- Why We can’t ERASE our paintings?. We need erase some parts of our paints. If you’re working througth the damn-full-of-limitations Projection Master, and using a textrue for painting, sometimes you need put the texture in a determined place, but some parts of the stroke enters in places where you wan’t paint (usually, the limits of the stroke).
Well, then you are unable to erase the paint where you don’t wanna paint. If you try to erase it, only painting the second color, and overwritten all the nice perfect texture you had put here yet. This is a damn garbage.
I can’t continue like this…
