ZBrush Memory error
Hey guys!
Have any of you had any experience with this? Basically ZB has been working great- No probs in sculpting however come Displacement map creation time the error : Memory error- sorry this action could not be completed seccessfuly due to insufficient amount of system memory (RAM).
Now i am sure this is not the case. The pc is an I7 920, 6gigs ram, gtx260card running on win7 64bit.
I have searched for an explanation and I came across a fix- Run ZB as administrator- I tried this and Hey Presto it worked!I am using multi map exporter to do multi UV maps- and with running as admin I got my 6maps(well 7) out- There was an error due to my UV’s touching the borders causing artifacts and a whole extra map. This was done on 32bit.
Once the UV’s were fixed- I set it to 16bit- and…Error, this action…since the first success running as admin- nothing.No maps for me!
Now I know the computer can do it- it has done it- Does anybody have any idea’s? Annnybody? - but I cant be the only person who has had this? Anywho, any ideas will be much appreciated =)
Regards
EvilMrD
