ZBrush measurement system?
I’m having a problem exporting an object out of 3dsMax using GoZ.
I’m exporting out some stairs, they are about 3 meters tall from the bottom to top.
Anyway, when I GoZ them into Zbrush, my brushes are extremely small. It looks like this is due to the sizing issues.
Since I’m making an environment, keeping a consistent size is very important.
Is there a way to change the measurements in ZBrush, like universally scale up the brush system?
Or any other method would help…
Here’s a technique that I have found to kinda work (hack I guess).
Take the object you want to scale and right click on the scale modifer in 3ds max.
In the offset world option, scale it down to 1%.
Reset your XForms.
GOZ into ZBrush.
Once you’re done with ZBrush.
GOZ back into Max.
Scale up your object by 10,000%. (right click on scale modifer, offset world option)
Reset XForms.
:cry:
http://www.zbrushcentral.com/showthread.php?168239-Scaling-Issues-(GoZ-Blender-Max-etc-)-Solution-and-explanation&highlight=Scaling+issue
Thanks Doug, perfect! :smiley:
