Hi
I’m new to Zbrush and in general the world of CG.
I approached zbrush because in life I make the sculptress ( modeller would be more correct) and I wanted to create the illustrations, a friend recommended me this program so that at least the sculpture has a feel very close to the real one (just abbituarsi the tablet).
But I have several problems, and are in doubt whether this is my error or true bugs of the program.
Going in order:
- ZBrush crashes constantly. Not sure why, I think I have a machine powerful enough (16 gb of ram (even though, being 32-bit Zbrush sees 4), Phenon x6 1090T, GTX460 1 GB and HD system Intel SSD), certainly not a power monster, but I think can handle Zbrush correctly.
In a work session / study (6 hours), Zbrush crashes at least 4 / 5 times, especially if I try to import geometry from other software (blender and mode (but this is currently completing the trial). I did, as recommended by Pixologic, multithreaded optimization etc, but anything on, crashes often and every time I go to reload the saved interface, in addition to the tools I was working on (or I have miserably lost) … and the light box does not help me, since I keep my work files in a separate HD, he insists on always go and look in the folder defoult of zbrush. - Sometimes Zbrush behaves strange. The last thing that cannot solve is material allocation. Proceed as described in WIKI: chosen subtool, select MRGB or M , and then fill object. In my case, having previously prepared a texture in photoshop, and being equipped with UV subtool, load texture and when I Fill Object, zbrush also charged texture on the object properly (as polypaint). The problem is when I try to assign a material to another subtool,Zbrush going crazy and also change other subtool material previously assigned (I doing so: material choice, active RGB or MRGB or M button, then click Fillobject Palete colors).
With other tools (i.e. head in zbrush defoult present), assignment of these materials work properly and do not go away as soon as I select another material, like happend with my project… is it possible Zbrush don’t like the geometry? Sometime happened so, But why? Is there a reason? is already difficult to deal with customers, having also issue with piece of software mood just do not feel like it …
Thanks in advance to all those who want to help me out:)
PS: I found a solution about reload everytime my saved UI, is a bug, found solution here: http://www.zbrushcentral.com/showthread.php?160733-ZBrush-4R2-Troubleshooting-FAQ , but other issue remains.
