ZBrush keeps switching back to default directory in dialogs
Hello,
When I open ZBrush (Windows) and load a tool or import something the default directory is the ZBrush folder, which is fine. If I, however, browse to a different directory, this directory is not remembered for the next load/import. If I want to load a different tool, the directory in the dialog goes back to the default ZBrush install folder which is a bit annoying since I have to browse to my folder again. Is there an option in the prefs which allows ZBrush to remember the last opened folder? This was standard behavior in the previous releases, no? I think it was.
Patrick
Turn off Use ZFolders in the Preferences palette.
Ah thanks Aurick. That’s the setting I am looking for.
Patrick
