Hi.
I’m using Zbrush 4, tried Zbrush 3.5R3 and same thing happens.
Well, i have 12GB of ram and i also set the virtual memory of Windows 7 do 25GB, i set the compact mem in zbrush to the maximum which is 4GB, and i’m trying to sculpt a model of about 27million polygons, and zbrush is giving the error of insufficient and then, crashes, problem is, there is a lot of available memory, while i still can work with the model, i can see that the physical memory usage doesn’t even reach 5GB or 6GB, and yet, zbrush gives me that error.
I managed to reduce this problem by importing the model, already subdivided in level 2 from max, and then, import it to zbrush, and now i only need to subdivide it 2 more levels, before i needed to subd to level 5.
Even though i can work on it a bit longer, it still gives that error from time to time, specially whem i’m gonna save my work, since i can’t save my work, it really doesn’t do any good to me.
If anyone could help me on this matter, would be very appreciated.
