I start with zspheres, sculpt subdivs then made retopology and sculpt more.
](http://javascript%3Cb%3E%3C/b%3E:zb_insimg%28%27%27,%27problem.jpg%27,1,0%29)
what are your settings in zbrush
preferences>import/export???
I changed the title because I figured out that this problem is a ZBrush problem and not related with 3ds Max or XSI…
I got exactly the same result when I try to import the obj file which is only exported from ZBrush itself.
I turned off all settings in “importexport” menu under “preferences” and export lowest subdiv mesh (“Obj” and “Qud” on, others off) after then I immediately import the obj (“Mrg” and “Add” off, “Tri2Quad” and “Weld” set to 0).
Model scales down and young girl turns into an old witch.
