Zbrush high res mesh retopoligy 3DCoat pipeline?
Hi I am sort of an newbie to the zbrush 3dCoat pipeline !
Just wanna know if there is a method of going about retopologizing a high res mesh in zbrush via the auto retopology in 3dcoat like the goz method pipeline with zbrush and max?
Like i am bysy trying to make my first decent animated carracter and is up into my head in qeustions and little awnsers!
Could someone that have managed to animated a low poly caracter high res adaptive skin help me .
I wanna animated this carracter!
Also, how do I export the paint map that i painted over the high res model cuase it does not come up under the texture and displacement and normals when I used my alphas and colours etc when I want to unwrap in uv master .
How do I go about this !
I then just want to go z lke straight away so max have the painted model as it is why all this uv’s not just bang ?Painted model directly with skin and all baked
Thanks hope there is someone out there that could make sence of my noob qeustions.
Thanks a milion.
goddog
http://www.3d-coat.com/forum/index.php?showtopic=7186&view=&hl=&fromsearch=1
Read towards the bottom, also you can mess around with the fill holes and voids settings
