1) You can’t. For performance reasons, ZBrush uses its own virtual memory which is always in the ZBrush 4R2\vmem folder. If you want ZBrush to capitalize on your RAID, install ZBrush there. ZBrush itself has a very small footprint. As for any data, that you can create, you can put that elsewhere. If you’re doing that, my recommendation would be to place shortcuts in each of the Z folders (like ZBrush 4R2\ZMaterials) that point to where you have created your equivalent folder. These shortcuts will then show up in LightBox’s tabs or in any of the Load/Save windows that you launch.
- All plugins that Pixologic has released for version 4R2 are included and installed automatically (unless you said not to by a custom installation). Any additional plugins you wish to install go in the ZStartup\Zplugs folder. In fact, anything you want to load every time you launch ZBrush goes in its ZStartup subfolder category such as ZStartup\Materials. A maximum of 25 of each item type (except plugins) should be installed. Any additional items should go in the Z folders or your data folders.
