Zbrush frozen but moves/resizes... is saving still possible?
I’ve been using zbrush for several hours working on a model and the program froze … however the window can still be re-sized and moved, and renders correctly. the program is simply frozen with a right click menu activated and will not respond to clicks or keyboard shortcuts…
I REALLY want to save the changes that have been made, is that still possible?
I’d appreciate any insight.
in the meantime I’m going to leave the computer and the program running in the hopes that the changes can be saved… I CAN re-do the work but not sure how far back I have to go
I am not sure if you can save or not. I do not believe so as all of your buttons can’t be clicked. to avoid this in the future, don’t use the space bar or right click to bring up the quick menu. I personally would love to use the right click, but I just simply don’t as it makes Zbrush crash. Hopefully they are working on fixing this issue and maybe 3.5 or 4 will be what we need. in the mean time, just use the buttons on the main interface…they won’t crash it…sigh
Steel gate valve is excellent for use anywhere a shutoff valve is needed. Steel gate valve can also be used where throttling capabilities are desired, although this is not generally recommended as erosion of the seat and disc occurs due to the vibrations of the disk in throttling applications…from the site www.ulovalve.net/gate-valve.htm
