I have a problem with Zbrush crashing from time to time, and I’m not sure if it’s something that only happens to me or if that’s something common that can be solved someway.
It usually happens when I press space bar to change the brush size, sometimes, just after the popup menu appears zbrush freezes and stops working. When it does that, the only way to get out of it is pressing ctrl + alt + del and to close it from there, losing the work that wasn’t saved before the crash.
Anybody else had that problem or knows how to avoid it?
